we would need additional information as to the circumstances that surrounds this event.I have a 2023 Ascent and the driver door unlock itself when the key fob is not around. Help please.
Just to be sure, I suggest checking the settings and replacing the battery in the FOB. There have been no widely reported instances of these problems, but certainly there is room for the sensor in a few handle units being a problem.Packout,
The key FOB stays in the closet when not being use about more or less 50ft away. I don't hear the door unlock. I just noticed at times when I go to the car, the car won't unlock when I reach to the door handle and the alarm won't chime, but the driver's door is already unlock and the rest of the doors are locked.
The settings for the doors are when you reach to the driver door handle, the alarm will disable and all the doors will unlock. When you press the key fob unlock once, the alarm disables and only the driver's door will unlock. I don't use Starlink to lock and unlock door coz I dont know how to use it.
Sounds like you are inadvertently pressing the unlock button on the fob in your pocket while walking away and then discovering it later when you return to the car.Packout,
