1 - 20 of 25 Posts
I get this when accelerating gently up the hill on my street, and when accelerating lightly (the Mitsubishi loaner car I had with a CVT did not do this under the same conditions). when I go in for my air conditioning service next week I'm going to ask them about that. .....This issue has popped up in number of different threads on the form.
Thank you.
Mine did this, or something like it. I think rather than it stopping I just got used to how to drive it knowing how to avoid that. It's like you use a lighter touch or a heavier touch on the accelerator to avoid it.
I've only had this occur in one particular place that I drive regularly...a moderate up-hill section of a street where the speed limit is only 25 mph and strictly enforced. I'm a "light foot" driver regardless but the combination of slow speed and upward incline just causes a little "hunting" by the software to find the ideal ratio for the small touch I have on the skinny pedal. It doesn't happen every time and doesn't happen at all if I'm closer to a "criminal" 30 mph in that spot.
BTW, it has nothing to do with the trim level being Touring. The drivetrain is the same across all Ascent trims.
2020 Touring surges during light to moderate acceleration, anyone else?
Yes this happens on my 2019. I would say it started at around 1500 miles or so, I only have 3200 on it now. I took it into the dealership, they said it is a known issue requiring a computer fix - not sure if I believe that or not. Disappointed since I waited a year to get this vehicle after being a long time happy Honda customer but the Ascent fit was I was looking for over the new style of Honda Pilot.
Same hill, same throttle setting, warmed up (at least 195F), does it still rev to 3000? Mine does it cold on a particular shallow hill on my street, but if fully warmed up, it can do it at 2000 with low throttlw pedal (cold, it revs no matter what - probably because it has trouble getting the torque when cold).
F.S.
We started experiencing the shudder issue with our 2020 ascent Limited after owning it about 20 months. We took it last week and the serviceman was able to see it happen! We got word this morning that we are getting a warranty replacement transmission!
What's your build date?
Drivers b pillar, black sticker, top right corner, month and year.
2021 Touring - I noticed the same thing. It just occurred yesterday for the first time. 2300 miles. I'm in NC and the in-laws have a steep driveway. Going up slowly caused the issue.
What happens if you turn off Eyesight pre-collision braking?
I will try that tonight if I remember. We are headed over there for dinner. We have, however, gone up their driveway 3 or 4 times already and only noticed it last night for the first time. I don't think it's a breaking issue - more of a sputtering for about 1/2 second and then it resolves itself. I think it's just the system trying to figure things out. Once it does, everything works. And if I recall correctly, it was on the initial acceleration at the bottom of the hill.
1 - 20 of 25 Posts
