Does anyone know if its possible to add the 120v power outlet to the limited?
There is the an outlet in the center console in the front of the car and then there is one in the rear cargo area. Other than that just the 6 USB portsDo the limited trim come with cig lighter outlet ?
No and no Subaru option to add it. I’m going to simply use an inverter from amazon. $20 solution.Do the limited trim come with cig lighter outlet ?
I believe there is the ability to do it. I think it involves ripping out the seat and other fun stuff.Does anyone know if its possible to add the 120v power outlet to the limited?
Could you update your recent project for 120v outlet ?I believe there is the ability to do it. I think it involves ripping out the seat and other fun stuff.
I don't think they pre wired and then allowing just for the outlet to be installed in the console in the 2nd row.
If I can find the plans I will attach them
Different wiring harnesses for the ones with the 120 Outlet.If I can find the plans I will attach them
What are you trying to run?Does anyone know if its possible to add the 120v power outlet to the limited?
81870XC32A for everything BUT the Touring.
81870XC20A for the Touring. And then you add 86711XC00A for the Power Outlet itself.
Just checked and there's also an inverter that needs added as well.Has anyone ordered the abov elisted parts and instaled them in the Limited?
My touring has USB ports all over it. I looked at the 110 outlet and my kids had their iPad charger plugged in it. Yep so far all I have used the 110 outlet for was... to use it for a usb charging port. :tango_face_surprise:nerd:
